more arlo accounts
  • 1 Reply
  • 1198 Views
timmermaster
Hello,
i have 5 sets of the arlo cams, all with there own account, how can i easy switch between my accounts, or must i always write everything agin in the app (password and email)
Use Settings, Grant access on each of 4 systems/accounts to the email address for the 5th one.  Once you go through the acceptance setup for each of the 4 invitations, you should be able to see all cameras on that one account's login.  Note that even with Allow Access Rights enabled, you'll be limited as to what you can do with the guest access but you will be able to view and work with modes and the schedule.
