cameras not showing in app or online
  • 4 Replies
  • 3127 Views
norrisbd27
I have 3 cameras and have been using the app for over a year now with no problems until recently.  Now when I open the app (iOS v 2.1.2) the cameras tab only show the option to "Add Device" where it used to show all 3 of my cameras and allow me to view a live feed if I wanted.  I also went into SETTINGS - SYSTEM - CAMERA ORDER and there is nothing there either.  The system is recording when detecting movement so that part is working fine.  I accessed my system on a computer as well and it's not showing the camera there either.  Any suggestions?  Thanks in advance!
norrisbd27
They didn't show there either.  I ended up removing the base device from my account, adding it back then having to sync up each camera.  I was hoping to avoid having to do that.  Thanks for all the suggestions.
For the "bad" camera.... go to settings then camera and REMOVE DEVICE ( bottom of page ) the camera completely.
Then bring it back as new ( re-sync required )( remember a quick push on the base sync nbutton ,don't hold )
norrisbd27
There is nothing under settings for camera.  If i choose "My Devices" it only shows my base station.  If I choose "Camera Order" under System it doesn't show any of my cameras there either.
Under Settings, the Arlo base , click on that and the cameras should show
norrisbd27
