Where can I find the "Cloud Storage" info in my Arlo app. It used to be available before the update.
  • 4 Replies
  • 1525 Views
Hairfarm
Where can I find the "Cloud Storage" info in my Arlo app. I want to be able to see the available storage I have left on the cloud.
No need. It's all about days in your plan with no space limit.
Hairfarm
Thanks for the response, but I'm too not sure what that means.  I have the free subscription plan. How many days do I have before files are deleted? Can you provide a link?
thanks
The free plan allows you to keep 7 days of videos before they're automatically removed. This happens on a rotating basis so you never run out. I would have thought you would check out the plans before purchasing but here's the direct link:
https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-the-available-Arlo-subscription-plans-...
Note that they're out of date inasmuch as they still reference the data size limitations but Arlo moderators and support have verified the removal of that restriction.
Hairfarm
Thanks for the response! That's what I was looking for.
