  • 6 Replies
  • 2115 Views
MKGAULIN
When camera 1 is triggered by motion can it be configured to record on camera 1 AND on camera 2 as well?
read this first; https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-create-a-mode-for-my-Arlo-Pro-Wire-Fre...
Then do a search ( green box above) as search is your friend for "nested rules" and read a whole bunch
Last tip; after you first CREATE a new Mode and add the first camera and save, then go back and EDIT it to add the second camera ( or third... )
6 REPLIES 6
Rules in custom mode;
sense cam 1 , record cam 2
sense cam 1, record cam 1
MKGAULIN
Thank you for the tip Tom! I was searching for how to do that. Can you point the way?
Mark
MKGAULIN
Thanks again Tom!!
MKGAULIN
My cameras have switched to black and white and I can't find any setting for that???
MKGAULIN
Nevermind. It got dark out and it switched to night vision
