Unable to resolve host - android app
  • 13 Replies
  • 22118 Views
  • 8 In Conversation
abc123
When I try to log in on my android app, i get thw following error message: "unable to resolve host "arlo.netgear.com": No address associated with hostname."  Any idea what's going on?
13 REPLIES 13
On WiFi or cell service?  If the former, it sounds like the router has a DNS issue.  You could try uninstalling and reinstalling the app as a first step...
abc123
Tried the app reinstall route and it still happened.  I was on my mobile -- it connects both to the cell network and to my Wifi, so not sure which I was using. I think it was connected to the Wifi primarily, so I suspect it is a Wifi-related problem.  Thanks!
stacy7
Hi i hav the same issue bt i tried reinstalling the app and it didnt work. Any ideas of what may be the peoblem? Thnks much
On WiFi or cell? Try both to be sure.
Mongillo
I'm having the same issues. I tried uninstall and reinstall on both. Hasn't helped
mikeavs
Tried on laptop, same thing! comes back saying "server not found". It can't even load the page
Joryandsam
I cannot log on to the website or my app it says no address associated with host. I have Uninstaled and reinstalled the app and still nothing. When I have motion caught on the camera I get an alert but cannot pull up anything.
HappyMaddy
I am getting the same error message. I can't get home right now to try and login there, would like the app on my cell to work especially when I get a motion alert. Request assistance.
We are investigating this issue immediately. Thank you for posting.
Hmmm. I haven't had any problems so far. ISP DNS issues?
mikeavs
it seems to be fixed as of 7PM EST
What ISP(s) were all of you using?
mikeavs
I am in Ontario, Canada - ISP start communications
