Turning off motion detection
  • 8 Replies
  • 24483 Views
  • 4 Likes
  • 6 In Conversation
Mikeshop
How do I set up a rule that shuts off motion detection? I can lower it to 1%, however, I don't see an option to turn it off.
8 REPLIES 8
David_NG
Hello Mikeshop,
Your question was answered in the Arlo thread listed below
How do I turn a camera off
Please let me know if you have any more questions
The Arlo Team
slijack
Ok, Im in settings, then mode, then create new mode, I name it motion off and then there is on only three icos, if I click one they all go active, the app does not allow to activate the icons individually so how is it that I can stop the motion?
naplee
Thanks for the input on this thread.
As of Jan-27-2017, the ARLO NETGEAR LOGIN site, gave me this solution: - Custom MODE + several RULES for each camera.
Thanks.  -Nap
naplee
Continuation of above post:
Pic can be seen by logging into NETGEAR forum,  -OR- by going to here:
URL-to-picture
PS:  I could only un-check the SEND EMAIL ALERT, by  turning Recording ON, if an Audio is detected in the family room.
           Alternative is to keep the SEND EMAIL ALERT, but send to a dummy email address.
I also mentioned the date of my custom MODE settings, above in my first post , since the ARLO NETGEAR website, seems to be in flux, each year.
Regards,    -Nap
Need
I've tried many times still can't turn motion off so frustrated.
Anyone can help for arlo pro.
Depends on what you're trying to do.  If you want all cameras disarmed so nothing is detected/recorded, use the MOde tab and use the Disarmed mode.  If you want to disable a specific camera, it may be better to use Settings, My Devices, your camera, On/Off slider. That will disable the camera rather than disarm it.
Or are you after something else?
Need
I just want to turn off specific cameras motion I have 2 into living/family and other 2 into front/back yard rather than On/Off slider.
Any other options?
Unfortunately, that's not the full story.  WHEN do you want them off/disarmed?  It sounds like you need to make custom modes with only the specific cameras enabled.  Go to the Mode tab, click on your base and create a new mode. Set up one camera and save.  Reedit the new mode to add additional cameras.  Any camera with no rule is disarmed. Create another new mode with a different set of cameras if needed and perhaps use the schedule.
Mode 1
-indoor camera 1
-indoor camera 2
Mode 2
- outdoor camera 1
- outdoor camera 2
Mode 3
- indoor camera 1
- outdoor camera 2
Mode 4
- indoor camera 1
- indoor camera 2
- outdoor camera 1
- outdoor camera 2
Schedule
12:00 AM - 6:00 AM - Mode 4
6:01 AM - 8:00 AM - Mode 2
8:01 AM - 4:00 PM - Mode 1
4:01 PM - 10:00 PM - Mode 3
10:00 PM - 11:59 PM - Mode 4
