Recording Duration Settings
  • 2 Replies
  • 1295 Views
manfredz
Hero
Hero
I've only had my 4 cam system working for a week and maybe I'm a little dense or you made changing the recording length to 120 sec too hard because it took me until today to finally get it right.
Would be much easier if in the screen which displays the cams under settings for each cam you also add sliders for duration (and maybe sensetivity) so one doesnt have to play around with rules.
 The catch is that you may not want a global setting for the recording length.  That's why you set it in your modes/rules so you can fine-tune the length according to the needs/desires.
manfredz
Hero
Hero
hadn't considered that possibility, but you're right, but no reason not to add to each cam's settings for those who want it straight forward and still leave it for modes/rules, giving that the override, or would that be too confusing/impractical?
Kind of moot to me now once I figured out the rule way, but took a while before I got it straight
