Software rules that will cause multiple cameras on one network to record when1 camera senses motion
  • 1687 Views
jerryh1987
I am setting up 2 cameras opposite one another (more or less facing one another) in a large space. I would like both cameras to record if one of the cameras senses motion. This will give me to 2 angles and greatly reduce blind spots.
This seems like a simple software modification. Allow rules whereby IF [select camera] senses motion THEN [select camera(s)] record. Then you specifiy the recording length and other parameters.
I think this would greatly improve the usefulness of this system.
jerryh1987,
This can be done by setting up a custom mode.
If you have cameras A and B your rules within the custom mode would look like this:
 If camera A detects motion, record on camera A
 If camera A detects motion, record on camera B
 If camera B detects motion, record on camera B
 If camera B detects motion, record on camera A
For more information on creating cusom rules, see here: What are Rules and how do I create them?
jerryh1987
The custom rule does not work for me. Never does it give me an option to record on a different camera from the triggering camera. In other words, when I do it, Step 9 from the linked instructions for creating custom rules (the step that allows you to activate a camera different than the triggering camera) does not exist.
Is this because I am using Arlo Qs?
jerryh1987,
This feature currently is only available for use with Arlo Wire-Free devices. It is not a feature available for Arlo Q or Arlo Q Plus.
