  • 2 Replies
  • 2262 Views
Mackey
Hello,
 I just installed three arlo cameras and plan on adding two more in the next few weeks. Can I set up each camera for different motion? I want my fornt door camera to detect motion at all times. Some of the other cameras I do not want to set up at all times. Thank You.
It's all in the Rules and Modes. Once you set up Rules for the various cameras, put them in appropriate Modes which can then be set into the schedule.  Takes a little bit of thought to get it right but not hard once you get the process down.
Yes...
As above plus try and name your MODE by what it does to make it easy...
Such as ;
FRONT DOOR ON ONLY
BACKYARD ON ONLY
LIVINGROOM ON ONLY
ALL CAMS ON
ALL CAMS OFF
etc
Remember that ONLY ONE mode can run at a time, the new mode over-writes the previous. So with previous if you have FRONT DOOR ONLY on and turn on BACKYARD " " , it will turn on the BACKYARD but also turn off the FRONT YARD
