  • 10 Replies
  • 2547 Views
  • 6 In Conversation
nicholshornlake
Luminary
Luminary
I run all my wireless cameras from a schedule, but after the last update the schedule in modes is so small that it can't be read. Anyone else? How to fix.
nicholshornlake
Luminary
Luminary
Thanks JamesC. I had it pinned to taskbar with ie, pinned it with chrome and now all is well. Thanks again.
10 REPLIES 10
Looks the same to me.  Try logging out and back in.  If that doesn't help, try reinstalling the app.
nicholshornlake
Luminary
Luminary
I have logged out then in with no change. Is the same with chrome and internet explorer.
nicholshornlake
Luminary
Luminary
what device , what os/version ??
nicholshornlake
Luminary
Luminary
Desktop pc, windows 10, google chrome, internet explorer
Wizard2016
If on your computer, hold the CTRL button down and move your mouse wheel. It sounds like you zoomed out. By doing what I listed above you can zoom in or out to your liking.
nickmobbs
Hi,
I have seen this issue also... no amount of zooming in or out made any difference.
That was in IE....
Using firefox it is ok.....
Regards
Nick
nicholshornlake,
I see the same behavior using IE11 and have escalated this issue. I do not however see this in Chrome or Firefox, consider making sure your version of Chrome/flash player is up to date.
nicholshornlake
Luminary
Luminary
