Samsung S6, recent Arlo Update
  • 2 Replies
  • 1744 Views
rkay
Arlo just updated my app on my Android Galaxy S6.  What i can't find is how to delete multiple files from the Library setting.  The old app you could click on Select all and then delete.   I can't see how to do that other than delete individual image files.  This becomes quite a chore if I have several days of detection in the library.  Am I missing something?
Yes...maybe missing something  ... its hidden a bit.
go to Library
see snaps of vids
push on one of them , IIRR they turn green? or get a check mark
In the upper right hand corner two boxes appear, one with solid dots , one hollow dots.
Solid dot box selects ALL, hollow dots box unselects all
For the Android app (can't speak for iOS), press and hold a video to get a box and a checkmark in the upper right.  Note the two new icons at the top right where you can select all (filled in boxes) or deselect all (empty boxes). you can use those or simply additionally select the videos you wish to act on.  At the bottom right are the options - trash, share, download.
