I set my cameras to record for 30 seconds but it only records for 10 seconds. Any suggestions? Thanks
Message 1 of 4
2,214
Silly question but did you save. Also, are you using the default Armed mode? If so, don't. Create your own custom mode and make whatever settings you choose. Use that one instead of Armed.
Message 2 of 4
2,412
Message 2 of 4
2,413
Ok I will try that. I'll keep u posted. Thanks
Message 3 of 4
2,190
You were right on the money. I was using the default mode. Re figured everything out and all is work as I need it to work. Thank you.
Message 4 of 4
2,174
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
