  • 2210 Views
Ematt96
I set my cameras to record for 30 seconds but it only records for 10 seconds. Any suggestions? Thanks
Silly question but did you save. Also, are you using the default Armed mode? If so, don't. Create your own custom mode and make whatever settings you choose. Use that one instead of Armed.
Ematt96
Ok I will try that. I'll keep u posted. Thanks
Ematt96
You were right on the money. I was using the default mode. Re figured everything out and all is work as I need it to work. Thank you.
