  • 4 Replies
  • 2413 Views
lesliechu
Hi everyone,
Both my and my wife's iphone received push notification saying a motion has been detected at one of the cameras. However, there are no new videos recorded in the library. Does any one has the same issue? Any suggestion?
Thanks,
Leslie
There are occasionally issues like this reported.  Have the videos now shown up?  Sometimes there is a big lag between notification and the video showing up.  Also, be sure the Library filter is cleared by clickin on the funnel-looking icon at the top and choosing reset and save.  The filter should then be "empty", not filled in.
lesliechu
 thanks  for your  answer.  I  checked the  filter  but  there  was  nothing wrong.
 this  morning   when  I  switched  off  my  phone' s  fly  mode  I   got the  push notification  again  but  it  is  nothing  in  the  library.  There  was  no  problem  with  manaully  saving a  video  recorded and  the  motion  detection  works  normally  at  most  of  the  times.
Time for a trouble ticket since there's nothing you can do on your end.
fatcat25
 try taking the unit down that is sending the notification, remove the batteries, meanwhile, reset the base unit.  Put the batteries back in, wait tll the blue light flashes, then reset the whole unit.  I had a similar issue that was solved by doing this procedure.  Hope yoU figure it out.  sometimes the signal gets confused and re-setting the whole unit wll stop whatever the issue is.  if that doesn't work, the ppl at arlo are really great about helping you out. Before dong this, check in "mode" that all your settngs are set, and SAVE b/4 leaving. (there s  one at the top and one on bottom of page dependng where you r) Let us know if you get this solved so we'll all know how it turns out.
