New update again OMG
  • 10 Replies
  • 3787 Views
  • 5 In Conversation
7948luis
After the new update that I just got keeps showing that my batties are about dead that I just installed anyone else seeing this? And again updates on motion detection are slow again
When first getting status, the battery shows empty.  When status has been updated, actual level is shown. Ignore the initial indication - wait for status to be completed.
10 REPLIES 10
Boat52
All my Arlo cameras are showing motion but not recording anything. It does seem that everytime there is a software upgrade things go nutsy. Very disappoinintg, to say it being politically correct. Hello Arlo team, are you there?
I've seen my running men indicating motion in a browser while the app shows just armed.  Looks like there's some bugs to be worked out.  If you're concerned, try both the app and a browser for confirmation.  Notifications being turned on may also be comforting.
I have escalated these concerns to engineering and will post a response as soon as I can.
Are you noticing any of these behaviors on the app (iOS or Android) as well?
7948luis
I have Android
My apps on Android seem to be fine with the exceptions of 1) attempting to use Settings on 4.2.2 causes a force close and 2) getting status on everything seems a bit hokey - I have to log out and back in, sometimes multiple times, to get a proper display and status.
jguerdat,
Try clearing your browser cache if you are experiencing the running man indicating motion being detected (even when there is no motion). Please let me know if you still see this behavior afterwards.
nickmobbs
I have this issue also.
Tried clearing cache... issue solved!!
Worked here, too.
7948luis
Still keeps say Low Battery then full
