  • 4 Replies
  • 19124 Views
  • 2 Likes
DianeG
Hi All, I'm so frustrated!  I purchased this system about 2 weeks ago and it worked fine until one of the cameras wouldn't go into motion off mode.  I did everything I could to turn it off and finally I deactivated the base, which was probably a mistake, but one I got it up and running again and resync'd the cameras to it, the motion on mode won't work.  The firmware on the cameras won't update, the base firmware is updated, I removed the batteries, waited a minute and then put the batteries back in, still no update.  I thought this would be a great system for me but trying to get this simple system to work makes me want to throw it against the wall.  Does anyone have any recommendations to fix this?  If I can't get it working by this weekend it's going back.  Another frustrating thing is there is no help number or email and it looks as if I'm the only one having this issue.
Thanks in advance for your help!
David_NG
Hello Diana,
I’m sorry to hear you’re having trouble with your Arlo system. Currently I see your base station online with the current firmware being 1.3.2261 (up-to-date) and your camera firmware being 1.1.2074 (which is the current firmware). I will list the steps needed to activate motion detection and deactivate motion detection.
Log into your account > Settings > Modes
(Please make sure you have the following modes listed)
All motion on & all motion off
(Note: If you don’t have these modes please create them by clicking “add” in the top right hand corner. Name the Mode “All motion on or All motion off, depending on what action you are needing and click save and save again)
Edit the “All motion on mode” by clicking on the pencil icon to the right.
Please make sure that all cameras you wish to detect motion are check with a green check mark. Once all cameras are configured please click save.
Edit the “All motion off mode” by clicking on the pencil icon to the right.
This mode is to configure no motion detection. Please make sure all cameras
In this mode have a black check mark. After configuring please make sure to click save.
Now please navigate to modes (weekly calendar)
Place the motion detection mode where you need motion detection to happen and place the no motion detection mode where you don’t need motion detection.
After setting your weekly calendar click save.
If you are still having trouble please let me know and I will reach out to you by phone if need be.
The Arlo Team
David S.
David_NG
Hello Diana,
The Arlo Team
David S.
DianeG
Thanks David S, it worked!
STLSR
Would like to turn 1 camera on off as needed without schedule please
ChristineT
Good morning STLSR,
You can accomplish this by creating a custom/new mode and configuring how you'd like your individual cameras to behave while the custom mode is enabled. Check out the following article for instructions on how to create a custom mode:
How do I create a Mode to assign different actions to each camera
Thank you for your contribution to the Arlo Community!
Best Wishes,
Christine
NETGEAR Community Team
____
Please click KUDOS or REPLY if you found this helpful.
