  • 27 Replies
  • 11822 Views
  • 5 Likes
  • 10 In Conversation
Jarhead0331
Everytime I log into the app, whether from my Android, or from any one of my ipads, several if not all of my cameras detect motion and begin recording. Why is a recording triggered simply from logging in and is there anything that can be done to prevent this. The false alerts are annoying and its also a drain on the batteries. If there is no work around, is this a bug that is being worked on?
Thanks.
27 REPLIES 27
Based on another recent post in this forum, replacing the camera solved the issue.  Contact support using the Support link above.
Jarhead0331
^Reading comprehension...its a beautiful thing.
For the record, replacing the camera did not resolve the problem. Replacing the entire system with cameras manufactured by a totally separate company solved the problem. The Net Gear cameras went into the garbage.
Thanks.
Showguy
Virtuoso
Virtuoso
Replacing the camera did not work. Rotating the camera to a different spot caused the new camera put in the old location to do the same thing. Moving the base to Mars and back didn't work. The only Sollutions left is a trip to the dumpster.
