Motion Sensitivity Check
  • 2 Replies
  • 1988 Views
Craig483
Hi all,
When i do the motion sensitivity check. It will flash where i want it to, however when in operation, it will not start recording where it flashed previously? Any tips?
Schorschi
Prodigy
Prodigy
Are you sure you're using the same sensitivity in the respective rule as you had in the motion test?
Are you using the default Armed mode? If so, try creating a new (custom) mode and recreating all rules in it. Activate the new mode and see how it reacts to your motion.
Schorschi
Prodigy
Prodigy
Craig483
Thanks ill try creating a new mode
