Hi all,
When i do the motion sensitivity check. It will flash where i want it to, however when in operation, it will not start recording where it flashed previously? Any tips?
Message 1 of 3
1,974
Are you sure you're using the same sensitivity in the respective rule as you had in the motion test?
Are you using the default Armed mode? If so, try creating a new (custom) mode and recreating all rules in it. Activate the new mode and see how it reacts to your motion.
Message 2 of 3
2,501
Message 2 of 3
2,502
Thanks ill try creating a new mode
Message 3 of 3
1,960
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
