Lag time additional recordings same camera?
  • 1 Reply
  • 1998 Views
RobbyG
Is there a time out on the recording of the cameras after motion is detected before it will record again?
Example after the motion is detected and the cameras record a video...Is there a time period they cut off again before recording the video for the same camera?
Example...I am trying to determine if the Pet Sitter is doing the work.
Camera 1 goes off at 11:34 AM and shows my cat going towards the window at the door (he does this when he has been inside for some time and someone pulls up in the driveway).  I got the 20 second video of the cat's motion.
Then 3 minutes later the at 11:37 AM I get an alert about a second video on the same camera.  Yet there is nothing in the video.  I am wondering if in the 3 minutes the cat sitter opened the door and let the cat out.
Essentially is there a default in the cameras that after motion is detected and recorded, the cameras will only start to record again at 2-3 minutes?
Thanks in advance.
Sound more like you nedd to adjust the sensitivity to increase a second capture on motion...
As to the original question, I've seen no more than about 10 sec delay for the next video to start if motion continues ( usu closer for me to <5 sec ).
And as most, the delay from trigger to record can vary. I get about a 2 sec delay to start, some get much more... I know my cat starts motion and depending how quick she moves can be gone from the video in the 2 seconds.
