Is there a way to auto arm the system?
  • 2 Replies
  • 2925 Views
alm99
For instance, some days I work from home, other days I may come home early. I have the system running in geofencing mode and scheduling mode. The system is set to arm during normal working hours mon-fri by schedule. The system stays armed even if I am home and geofencing mode is active. This creates an issue if I am working outside and the cameras continue to be triggered so I am forced to disarm the system manually through the app. Well, you know what happens next.... I forget to rearm the system.
Is there a way to have it set that if I disarm the system that it will automatically rearm once the next scheduled time is?
alm99,
It sounds like you would want your Geofencing settings to show the Home Mode as "disarmed" and the Away mode as "Schedule".
This would keep the cameras disarmed when you are inside the location radius and arm the camera when you are outside the radius (within the schedule conditions).
alm99
JamesC wrote:
alm99,
Thanks! I will find out when I get home if this works.
However, if I do this then, the schedule doesn't go into effect right? That's an issue when the cameras should be armed at night while we sleep.
