I want to run two cameras in motion but can't
  • 6 Replies
  • 2473 Views
Veteran
I have five camera's I'm sure I noticed all motions "MEN" were on when I started with this system and that i turned them of. Now I want to run two camera's in Motion mode but after many days of trying to figure it out I'm stumped. Is the issue because I'm on the basic free package?
You may have to make new Modes, by default you have ARMED ( all on ) and DISARMED ( all off )
If you have cams A, B, C ;
mode 1 could have A on only
mode 2 could have B on only
mode 3 could have C on only
mode 4 could have A & B on only
mode 5 could be A & C
last would be B & C
( use the combos you need but not necess all )
Go to ( after log in ) click on current mode on upper left
Box shows up with current modes
Click CREATE NEW MODE
follow steps,  naming the mode so u know waht it does.  Don't forget to save when needed ( usu at bottom of screen )
6 REPLIES 6
Veteran
This is not a user frendly piece of equipment.
PS to above and prev answered question... right now 'nested' rules don't seem to work as they did...
more to follow as time goes on.
Veteran
I dont understand the word NESTED I will be heading out country soon and I bought this system for our home and workshop.  Where are the tech's for this arlo system. I'm about to return it to best buy if this issue isnt resolved SOONEST!
Did you try to call support? There's a Support link at the top of the page. Forums are an informal way of communicating while using the official support mechanism is the recommended way of actually receiving support.
last would be B & C
Veteran
It looks like I am up and running with the motion sensors. Thanks for the info
The Veteran
