2 camers in one location ( front of home)
  • 1 Reply
  • 1186 Views
Tgaspari
IF I had a camera at the garage (front of house) and one at the front door (side of house)
My garage extends out from the front door.
Question is
If the garage door camera captured a clip will the front door also capture a clip if walking by the garage to the front door ?
Generally, yes.  The cameras are separate so as long as motion can be detected by both, they will record separate videos although probably with a start time difference.  Be aware that you can set rules to detect motion on one camera to start recording on another. You just have to make a rule for one camera but choose a different camera to record while making or editing that rule.
