  • 2 Replies
  • 1154 Views
MayamarG6
I have set  a schedule for one of my cameras but it seems while the schedule is set I can no longer access the device to adjust settings. Do I have to remove the schedule in order to do this?
MayamarG6
Thanks. Problem solved. My Mode was opening at the schedule. Navigation is a bit strange until you get used to it.
Nope, the schedule should have no effect on your ability to do anything.  Are you using the original master account for logging into the app/website or a guest account set up under Settings, Grant Access?  Try a power cycle of the base using the power switch and maybe opening and closing the battery door.  Any luck?
MayamarG6
