  • 6 Replies
  • 3413 Views
Trasina
I tried adding a mode for the one camera I want to shut motion detection off on. I go to mode and I choose the camera from the list. I then unselect the only option under "Trigger" for "when motion is detected" but as soon as I unselect that I cannot move on. The NEXT button is no longer an option so I select "when motion is detected" and go to the next screen but then I'm done and have not added a mode to turn that camera off.
Turning OFF the camera is totally different from using a mode to turn motion detection OFF
In the first, the camera is totally off line while in the second the camera goes into a sleep mode and will not detect nor record for any motion but can be live viewed.
PS... yes on/off is a new option. It allows you to stop " friends " from viewing a camera you gave them access to or one you want private.
6 REPLIES 6
You can only have one mode running at a time... If you start a second mode, any camera NOT listed in that mode will be off.
So say you have 3 cameras... A, B, C
Default modes are ARMED ( all on ) and DISARMED ( all off )
for all the possible combos, you need to add a few modes ( use only what you need )
A on
B on
C on
A - B on
A - C on
B - C on
Now you want A & B on but not C
Add a new MODE putting A in it then save... Go back and EDIT the same mode and ADD camera B then save
Now if you have ARMED (all on ) mode running  on and want to turn off C , use the just created mode A&B... C turns off as it's not in the mode.
hope this makes sense 🙂
Trasina
TY, I had looked it up all over on here and everyone kept saying the only way to turn a camera off was by adding modes BUT I must have missed something because the app does have an on/off option for each camera. I went to Settings-My Devices and chose the camera I wanted from the list and then the very first option was on/off! I don't understand why in every answer to this similar question everyone has said you can't simply shut off one camera. Maybe it's a new option?
The camera on/off in Settings is a new option.
Beaglebakery
I don't have an on off option and I just bought my cameras. Do I have to download something?
Beaglebakery
Oops I found it.
