  • 4 Replies
  • 3075 Views
KT2016
We need to have option to enable and disable push notification for all cameras together with one button. Now it is time consuming and pain to take couple steps to enable/disable push notification for each camera one by one. Does anyone have a solution for it? Or hope they add this feature soon.
KT2016 wrote:
But I am not using IOS app. On Android app and web login there is no option to turn off  notifications. I see only this option in camera mode to enabl one by one for each camera.
On Android , go to Settings >Apps>pick Arlo...
uncheck the Notifications box
On web, the choice is only for each camera via edit of the mode
09KR0058
Just turn off notifications.  For example, on the iOS App, go to Settings -> Arlo -> Notifications and turn off Allow Notifications.
KT2016
KT2016
Thank you. It is a good solution. I was hopping they consider adding this tool but your solution works too to stop receiving notifications when we dont want to.
