Hello this is my problem and still I don't know how to delete it. 😞
Message 1 of 4
1,327
annapatty,
To remove a camera log in to your Arlo account and navigate to Settings > My Devices > select the desired camera > Remove Device.
Message 2 of 4
1,317
It's in "setting" and "camera order". And in "cameras". There is no way in those two areas to delete it. Also, I can't get this to keep my password. I have to go in and out of it to get it to work. It works after a few times, br what a pain, otherwise I have to keep entering my password. I tried to figure out what I am doing wrong, it happen after the IPhone 6S upgrade. Thanks
Message 3 of 4
1,269
annapatty,
The camera cannot be removed from "Camera order" or the cameras screen. Within "Settings" tap the desired camera and then you should see a black button with white letters "Remove Device". Tap "Remove Device" and this should remove the camera.
Message 4 of 4
1,260
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
