What a Trash update! Where can I turn off my email alerts, don't need 40-50 email about motions! I'm thinking of getting rid of this trash camera. Thanks!
Kudos to you Kind SIR! All I have to do is create a new rule and set it back up as my own settings! Uncheck the email notifications and bingo was his name O! Thanks!
Maybe editing the rule(s) would help. Mode tab, select your system, edit the various modes, turn off email notifications.
not sure what updates netgear have done, but in modes i have nothing other than it saying my base station is armend and only gives me options to arm, disarm, or schedule
this is rubbish we get an email constantly, if it cant be returend to how it was previous then i be after my money back
Do you see the "pencil" icon for each mode? That gives you access to edit the mode and turn notifications on and off.
After upgrading to Premuim yesterday I cannot get motion to stop notifications being emailed to me, even following the instruction under Mode and Push notifications editing, I even deleted my email address! This is very annoying. It was working properly with the free account. How do I turn this off?
Push notifications are for the app, not for email. Ensure that the email notification is turned off. Might be useful to turn them on, save, turn them off and save again.
How do I turn off email notifications everytime my device detects motion or sound
All notifications and other settings for motion detection are in your modes and rules. Use the Mode tab, click on your base station and edit your mode(s) using the pencil icon. Be sure to save your settings for both the rule and mode.
I don't see the pencil ico on the mode screen
Make sure you click on your base to see the modes. Depending on whether you're using the app or a browser, there should be a pencil or > on the right side of each mode to allow editing. Still not there?
Thanks. I see the > now. The email notification setting is only available in Armed mode, not in Schedule mode.
Correct. The schedule is just the schedule for any modes you choose.
Hi, I was trying to find how to disable alerts. Initially when I set the system up I thought I'd disabled email alerts. Now I am receiving email alerts again. To disable them it says to click the pencil icon in the mode>camera name settings. In settings mode when I'm in scheduled I don't have a pencil icon to edit. All it has is a an > icon which takes you to the times it is armed.
If I set a new rule for arming as I set it up I the notifications rules do come up.
Oh, I think I found it. If I change from scheduled armed setting to armed setting in (mode) then the camera settings come up and I can edit the notification rules. Click mode>arm the system, click the >, your cameras will be shown, click edit, the camera rules and notification methods are there to edit, click save
Hopefully they will apply in my scheduled mode. This needs to be pointed out in your help area, fyi. thx - J
You found the proper way. The schedule is not a mode, it's just a way to schedule your modes. If you want certain things at certain times, create a mode with those settings and then schedule it.
SO now we have to go through each camera individually and set up the rules? Then when we are done, and we select schedule, how does it know which custom rules we we want it to run on schedule? This setup process isn't very user friendly.
how do I turn off the email notifcations i keep getting when there is motion detected?
Go to the mode you are using to arm and edit the email options
GO to MODE
click on base
Modes appear on right side, pick ARMED ( or the one your using )
Hit > to edit
pick camera ( must be done for each )
go down the page an uncheck the email box
then SAVE
Go "Mode" and Locate whichever camera you want to edit under "Rules". Go all the way down if using App under "Alert" -> "Email". You can uncheck it if you don't want notified. Don't forget to save.
You can turn off alerts per camera....
Go to MODES and edit the current mode you are using... uncheck the alert boxes
https://kb.arlo.com/1019297/How-do-I-set-up-notifications-or-alerts
FAQs are your friend....almost all ?s have been answered
Added a new camera to our Arol system . It will not stop sending me push notifications emails. How can I make it stop?
Push notifications are toggled on/off within the rule for the camera in the mode you're in. So edit the mode you're in. Edit the rule pertaining to that camera and scroll down to see the options of push and email notifications. Turn the push notifications off. Click SAVE
Also, great to have a read through the user manual to familiarise yourself with how all the different modes and rules are used. Hope that helps
I would like to change my email notifications, so I am not getting emails any more when the Arlo takes a video.
The previous question on this topic did not have a response that was effective.
Thank you!
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
