How do I set automatic recording when a motion is detected
  • 1 Reply
  • 2130 Views
Valeriu
How can I go from manual recording to automatic recording when a motion is detected
Thank you
Manual recording is only available through live view.  Automatic recording is what happens when you use modes. By default the Armed mode is enabled and used. You can verify that recording is enabled by looking at the running men for each camera in the Devices tab. If they're black, recording is enabled. Gray means disarmed and nothing will be recorded.
