Guest notification
  • 1 Reply
  • 1658 Views
Murrs187
Is there a notification that lets you know if your guest (s) are currently viewing your camera? Thank you in advance.
tinokremer
I do not think you can see if someone is looking unless you have your camera's armed. If a live stream is opened, the black man turns gray, meaning it's no longer armed.
Also, if you are searching for a little privacy, you can disable a camera proactively, so guests cannot watch it in the first place, see: https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-use-the-Arlo-privacy-feature/ta-p/1085...
