  • 11 Replies
  • 7081 Views
  • 3 Likes
  • 5 In Conversation
Tdub4
Is it possible to use Geofencing mode in conjunction with the Schedule mode? It appears that I can only select one mode or the other but not engage both. For example, always arm the cameras when I am away but also arm them for a period of time at night even when I am home.
i must be missing something. TIA.
RobertRosal
Virtuoso
Virtuoso
You can accomplish this now.
I accomplished this by creating modes, let me try and explain the steps.
In this example, I want my indoor cameras to never be on while we are at home, but turn on when we are gone, but when I sleep I want them on.
Example:
  • Create a mode, like sleep.
  • In my sleep mode, set your cameras you want in it.
  • Open Schedule and set a schedule from 11pm - 6am for your sleep mode
  • Go to GeoFencing
  • Set your location
  • Set your enabled devices (all your phones)
  • Select Mode
    • Away Mode choose Armed, where armed will have all your cameras. If everyone leaves, they turn on, anyone comes back they turn off.
    • Home Mode choose Schedule, now when you are home between 11pm - 6am your cameras will be on.  If everyone leaves it'll switch to Away Mode, but if you come home, it all turns off.  Then at 11pm, geofencing sees you are at home, it turns on your schedule, if you all happen to leave in the evening, it'll switch to Away mode, so they will turn on regardless.
Now you can actually create more modes and add to your shedule to do more things, but the above instructions should work for you.
-Robert
11 REPLIES 11
Dill_
I literally just logged in to post this exact question, good to see I'm not the only one who would like this function as a setting rather than a mode. I did find a workaround using IFTTT.com but it does not take into consideration my wifes phone and mine like the Arlo mode can. Thanks Tdub4.
RobertRosal
Virtuoso
Virtuoso
Example:
  • Go to GeoFencing
  • Set your location
  • Select Mode
-Robert
Dill_
Robert,
Thanks, this does the trick! Got geofencing on with away mode set to Armed and Home to Schedule.
RobertRosal
Virtuoso
Virtuoso
Glad that worked out for you!
-Robert
JustLearning
Just checked the app to find a clock symbol next to my geofencing symbol by my Arlo Q camera. I have noticed that this camera has not been recording when it should. A neighbour is a beta tester, with devices before commercially available: is there a chance his devices or settings could affect mine? Can anyone explain what the clock means? Is there a possibility that scheduled geofencing has been set up? There are no other users & I haven't tried it!
The only clock icon for my Q is on the Devices tab, which is used for the CVR option.  The only clock icon in my Mode tab is for the schedule.  GF has a location indicator but no clock.
As for no recording, is the running man in the Devices tab gray or black?  If gray, it's disarmed - you need to set an active mode or the schedule in the Mode tab.  If the running man is black and all looks good, power cycle the camera and see if that helps.  You might also want to check your motion detection zones to see if they're set properly and used in your modes.
JustLearning
Geofencing icon, then clock icon, then disarmed. It should be armed and geofenced.
JustLearning
It records when set to arm, except it seems when the timer is on?
JustLearning
I haven't enabled zones. Sorry, typing on a phone!
You've lost me.  Take some screenshots of what you're seeing and post them here.
JustLearning
Any idea how to upload them? I'm on an iPhone and paste doesn't work.
