  • 1499 Views
Cdp224
I have issues with Geofencing moving between home and away over and over again, while I am at home.
Cdp224,
This could be an issue with the the size of your Geofencing Radius. Consider editing your Geofencing mode and increasing the detection Radius.
JamesC wrote:
Cdp224,
Very good James.....
This is due to what is known as GPS Jitter ... or the jumping of location due to variances.  Non-tech reasons are anything from intereference to low quality or assisted gps locations.... If you look at a data dump over time , you'l find the avg location is prob the best.
So an increase in radius eliminates the jitter which may be causing the problem ( in and out of set point )
Cdp224
I set the radius to Large, but still it changes from home to away and back to home every few minutes. I decided I just can't use that setting. Thank you for your help!
