Geofencing - Multiple Camera Modes
  • 8 Replies
  • 6026 Views
  • 5 In Conversation
Stephngeorge
Hi all. I have just bought Four Arlo Cameras and want to install them inside and out. I love the idea of geofencing, and would like to geofence the inside cameras and keep the outside ones always armed. I've read through the instructions and also tested a few different modes but can't seem to make it work. Can someone please let me know if this is possible. Thank you
Stephngeorge,
It sounds like the settings below are what you are looking for:
Geofencing settings:
"Home" - custom mode (no rules for inside cameras, motion detection rules for outside cameras)
"Away" - Armed
I hope this helps,
8 REPLIES 8
You will have to make one or two new modes to split the inside from outside cameras and then use the Geo zone function
( remember noly 1 mode can run at a time and any camera NOT in the current mode will be off.)
this may help; https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-create-a-mode-to-assign-different-acti...
Stephngeorge
Thank you. I can play around with the modes, but Im not sure I will end up with what I want. I have three cameras outside that I always want on, and two cameras inside that I want to geofence so they turn off when I am at home. Will this end up with two modes (which will mean only one mode at a time) or is there another way to do it. Cheers
Stephngeorge,
"Away" - Armed
I hope this helps,
Stephngeorge
Thanks James. I think I may have worked it out. Now to buy more cameras 🙂
Lilu
I'm having the same issue. I suppose I have to keep swapping modes constantly when I leave for work. That's a little annoying and I'm surprised it's not possible to add a schedule to the individual cameras. I would like the outside cameras on motion sensor all day and the indoor cameras on a schedule. Hopefully they will add that option soon.
Lilu,
You can currently do this by setting up custom modes within your schedule. Create a mode that includes only rules for the outside cameras and schedule it for daytime hours that you do not want the indoor cameras active. Schedule all other times as "Armed".
You can then use your "Away" mode within Geofencing as "Armed" and your "Home" mode as "Schedule".
Lilu
Thanks James. I guess I need to sit down and dive into it. I have not seen how to make the custom modes run on the schedule. I will keep trying!
Modes are simply assigned time slots in the schedule.
