Forced Recording
  • 1 Reply
  • 1329 Views
suelovesstu
Can you select motion only with no recording?  So you are alerted to movement but dont have the recording happening.
Then if you are alerted to motion and decide you want it recorded can you then start a recording?
Yes there is an option to " do nothing" in record section
Spoiler
And yes, you can start a manual record session any time
