Removing the Add Device Screen
  • 1915 Views
GAHARLEY
The "Add Device" screen takes up a lot of screen space in Devices mode.  For me, adding devices will occur infrequently.  Is there a way to remove that option from the Devices screen to free up space?  Hopefully, a device can be added some other way.
No and no. Can't remove it, can't add a different way.
GAHARLEY
Thank you for the response.  I realized after I posted the message that the screen's intent is for you to have two cameras and they would both appear side by side.  I'll just have to think about a second camera.
Indee
I agree. The home screen is precious real estate and should not be cluttered with a static Add Device pane.
