Trouble adding a new mode
  • 4 Replies
  • 2087 Views
  • 5 In Conversation
So_CA_Sailor
Step 2 under "Add a Mode" in the user manual (pg 38) says, "Click or tap Mode and a list of cameras displays".   When I click Mode only an icon and the serial number of the base station displays.  There is no list of cameras. The Camera, Library, and Settings seem to funcion OK and I have closed and opened my Arlo account several times on my PC, phone and iPad. The results are the same on all devices.  Everything seem to work OK except Mode. Help!!
The manual is maybe a bit wrong.....
If you click on Mode, an icon of the base appears, and if clicked on a list of modes will appear on right column.  You should first see the default modes , ARMED and DISARM... At bottom is Add Mode button
If in mode, and you click on ADD Mode, you should be prompted to name the new mode first
So_CA_Sailor
Thank you for bringing this to our attention. As TomMac states above, please select the base station and then the "Add Mode" option will be available.
I have submitted an edit request to better clarify these steps within the manual.
Thank you,
nateshort5
I don't have the green button "add mode" .  I have watched the youtube video and want to turn on driveway and turn off other cameras at certain times.  I just dont see the 'add mode' green button at all.  Help.
I think I just answered this in another thread.
Mode tab, click on your base.  Use the Add A Mode button at the bottom. Create the new mode and a rule for one caamera. Save.  Reedit the mode and add another rule, save, rinse and repeat, saving each time.  ANy camera without a rule will be disarmed.
