  • 7 Replies
  • 3295 Views
  • 6 In Conversation
ertert
Can you have different time settings for each camera?
For example one cam on continious and other two on timer/chedule.
7 REPLIES 7
davidr2
Yes, you can create rules for each camera.  Then create modes that include the rules.  The mode doesn't have to include every camera.  I have a daytime setting which ignores the backdoor as the dogs would set it off, but watches the side gates, garage and front door.
Finnster
It would be nice to be able to just turn on motion for an individual camera without creating "rules"
southerncuban
Is there a way to set up a schedule that turns on motion detection on different cameras at different times or do you have to just manually switch between modes? If it can be done then how? Also I was told you can copy one day's schedule into other days rather then having to do it one day at a time (ex same schedule Mon-Fri without typing in 5 times) but can't figure it out. I would love some assistance.
NavyGirl
Can anyone explain step by step instructions for setting different record times for different cameras with the updated app? I can't figure this out.
southerncuban
I went to the help section from the main app page then selected settings then help then support. I then typed in setting different recording times for different cameras and it gave me step by step directions. If you still need help after that let me know. I just figured it out today.
southerncuban
I figured it out!!
tigercub
The easiest way I found to figure out the updated system was to go to 'Help' from the 'Settings' page, then click on the 'Support' link, then go down the page and click on
'How do I create and define Modes & Rules?'
From there you get step by step instructions. Cat Happy
