  • 4 Replies
  • 2672 Views
  • 2 Likes
ChrisLuce
So I purchased the (Arlo Security System - 2 Wire-Free HD Cameras, Indoor/Outdoor, Night Vision (VMS3230) and received it on Friday (10-15-2016). I got everything setup and was happy. I really guess I sould have done more research because I discovered the Arlo Pro and all the features it now has to offer.
Now, should I send back the current model and pick up the new Pro? Two major features I really want is being able to add a portable drive to make storage local and also rechargeable batteries! The current Base Station has two USB ports on the back and I am wondering if they are ever going to be able to use external drives with those USB ports in the future?
What do you think is the better route, wait for future updates or return the current and get the new model?
Thanks!
Chris
ChrisLuce
Well, after some thought I have decided to wait until the new Base Stations are available and I am going to buy that instead of sending everything back and starting over. It would be WONDERFUL if Netgear had some type of Exchange/Trade In program if you are just buying the new Base Station. I want the new Base for local recording.
As for battery life on the cameras, I am just going to use the rechargeable batteries.
Chris
ChrisLuce
Chris
Remember that the regular Arlo system cameras are fully compatable with the new base unit so in the future if you decide, you can easily update the system ( and the new PRO base will be offered by itself )
ChrisLuce
TomMac,
Do you know when the new BaseStation is going to be available and how much will it run?
Thanks,
Chris
Soon...maybe... I hope... don't really know
