  • 4 Replies
  • 27365 Views
R_Lowe
Luminary
Luminary
If someone has a couple of common housecats, will they get a ton of notifications/recordings if they happen to lope around the house, or can sensitivity settings be adjusted to only include large living things over 50 pounds (w/apologies to a few huge Maine coons...)?
You can adjust down the sense of the motion detect... and its easier to do indoors as opposed to outside with more variables.
If you temp mount a camera near where the pet always goes, like a food dish, set the sense down all the way and then slowly up till you get a response for motion... just back off a bit then. Try and keep it at a range you will use when used in the normal location.
R_Lowe
Luminary
Luminary
Thanks for the suggestions Tom.  It sounds to me as if a little experimentation will go a long way.  Of course I'm just trying to avoid a bombardment of notifications.
Don't forget , there is a motion TEST mode ( SETTINGS, Pick camera ) which will flash the led if motion is detected.
Also, you can temp turn off the emails ( just check the recordings )... at least till you get closer to where it has to be set.
R_Lowe
Luminary
Luminary
Thanks.  I love socking this information away until my cameras arrive (next week)!  "Test" mode -- gotcha.
