  • 4 Replies
  • 2968 Views
Belinda45
How can I change the sensitivty of my cameras? When  I click on MODE there are no camera listed, only the base station is listed. I often get notifications over night from small particles in the air moving past one of my cameras. I would be grateful if someone could explin why my cameras aren't listed uder MODE and how I can change the senitivity of the camers. Apart from not being able to set the sensitivity the whole system works wondefully.
You stopped too soon.  You have to click on your base station to get into the modes.  Since some folks have multiple bases as well as Q cameras, there could be multiple selections to be made since they're separate entities.  Yes, I think they should able to be lumped together but that's not how it currently works.
Belinda45
When i click on the base station it takes me to the screen with arm, disarm, schedule and geoforce.  I still cant change my sensitivity
I'd suggest creating your own custom mode rather than editing the default Armed.  But anyways, edit the mode you're using.  That's how you make changes to settings such as sensitivity, recording length and notifications.  Be sure to save at the end of your editing.
Belinda45,
Take a look at this step by step article on adjusting camera sensitivity: How do I change the motion sensitivity on my Arlo cameras?
I hope this helps,
