Arlo web app, flashplayer update
  • 3120 Views
  • 2 Likes
afeid
I installed a couple cams a few days ago. I'm planning on expanding (once I order some real camera
mounts to use instead of the low-quality ones included with the cameras). One issue I've noticed
is that I keep gettiing prompted to update my Adobe Flash every time I try to log on. I've been
sharing the details of these cameras with my friends because, despite some very basic issues with
the cameras and mounts, I think they're a good product and could become some of the best on
the market. I mentioned the issue with AFP to a friend of mine (who actually out-geeks me) and
he said it's common for sites to raise revenue by partnering with Adobe so that when users are
directed to upgrade Flash, and Adobe installs 2-4 extra apps (McAfee, MS stuff, etc), the
company which redirected gets a cut of profits. My friend may outgeek me in some areas, but
frankly I find it hard to believe that this practice is common, and that it's the cause of the flash
messages. At any rate, if others are having this issue, it would be nice to know. FF browser,
v 45.0.1,
Just try Chrome since FF is giving you trouble.... it's amazing that some just plain work with less headaches than other , but it varies on each computer
afeid
Good idea. I started using FF a long time ago when IE became bloated, guess it's time to switch.
FWIW, any time you update Flash (or other Adobe products) you are presented with the option to deselect the "added value" additional software.  I have always done this to the point of even using the custom install option on some software to ensure that I only install what I want.
