Hi,
I installed the iOS Arlo app on iPhone6 and the phone language is Chinese. But the app doesn't follow the phone setting, it display english menu instead. Anyone has similar issue?
Thanks.
Message 1 of 6
4,369
5 REPLIES 5
ML,
Unfortunately, Chinese is not a supported language on the Arlo app at this time.
Regards,
JameC,
When will it be supported? Thanks.
ML,
I don't have any information on when it will be supported. Be sure to check the notes when the app updates.
Regards,
Message 4 of 6
4,312
Merci de m'informer pour l'accès en français..
Message 5 of 6
3,989
Adding the Chinese language support is definitely a plus because I bought it for my dad who doesn't read English.
Message 6 of 6
3,914
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
