Arlo Q talk icon ( Mic) fail on Iphone 5s with iOS 7.2
Firmware is up to date ( 10/05/16)
When press talk icon ( Mic) on my iphone 5s , the whole app shutdown , and phone turn to it home screen. Plz help
Message 1 of 4
1,095
Answered in other thread...
Since it works on your other phone with a newer IOS version, you may need to update the IOS on your 5s phone
Message 2 of 4
1,091
Is there an update for the app that would work for iOS 7 ? ( it says in the Arlo app that it's compatible for iOS 7.0 and later ).
Plus when I set up Arlo Q , there is no "confirm " button on connect to net work step on IOS 7.0. I want to keep the same iOS 7.2 on my phone because I have some apps that don't support new iOS 9.0
Message 3 of 4
1,088
Andyle,
If you're having issues with the app when using an older iOS version than what is available, please update your iOS to the latest version and try again. As TomMac suggests above, it sounds like the issue is the older iOS version on your iphone 5s.
Message 4 of 4
1,072
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
