  • 5 Replies
  • 3602 Views
  • 5 In Conversation
CJ180
Is there any further information regarding the solar panel that will be released for the Arlo Pro?
5 REPLIES 5
Not Yet
SilverSentinel
sam8599
can someone confirm if used this solar Panel and it works? Reason, if you try any solar charger at home (out put 1 or 2.1A) and use with Arlo pro, does not  work. Seems the system is "locked" to use Netgear accessories. As a matter of fact you cannot even use a generic micro usb cable & charger to charge the battery.
kit07248
This one works for me, it needs the quick charge port, the one with the green colored usb which supplys 9V/1.5A.
https://www.amazon.com/gp/product/B014IIUXO2/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
sam8599
Don't see any option how to make it water/rain proof? Have you tried installing outside and connectors are water protected?
