Arlo Pro AddOn Base, Smartthings and add-on sirens
  • 1 Reply
  • 2619 Views
gzafra
Hi there,
I apologise for so many questions in a thread but I just got a new Arlo system and have too many questions 🙂
First of all is regarding positioning. I'm not sure where I read that it's best located away from the home WIFI spot so that it doesn't interfere with it and thus batteries last longer.
2nd, as I have the old Arlo base, if I wanted to add a new add-on base, could this be the arlo pro new base so that I can enjoy the features (siren & local storage) ?
Also, I'm thinking of adding a smart system for more sensors and lights. Heard the SmartThings is compatible with Arlo which could add some nice features. Does anyone recommend this or maybe another?
Thanks in advance 🙂
1) not necessary,  My base sits 6 ft from my home wifi router and doesn't have any problems.... most interference comes from other wifi transmitters ( like neighbors , etc )
2) Yes... you can add a pro base and it will support both Arlo and Arlo Pro cameras...any camera synced to the PRO base will pick up the siren and local record feature ( but not audio as they are in the pro camera only )
3) IFTTT  works fairly well, how much other smart things link is base on what you use,  it's all basicly new tech
read ;   https://community.netgear.com/t5/Arlo-Knowledge-Base/What-is-IFTTT-and-how-do-I-use-it-with-my-Arlo-...
