As my subject suggests I have Arlo Pro and Solar Panel Wasserstein.
When I added solar panel it used to slow down discharging of my Arlo Pro battery, e.g. it would not actually charged it.
However lately I see my Arlo Pro battery being actually charged.
Not that I complain 🙂 But wondering, what happened? Did Netgear improved firmware to be able to do so ?
Thx
Message 1 of 5
8,132
More than likely yes. The wasserstein solar panels work well . ive used them for over a year no issues
Message 2 of 5
8,126
Thx
Did you observe the same behaivor ?
Are your Arlo getting charged by solar ?
Message 3 of 5
8,123
Mine are on the wasserstein panel. The only problems ive had is back in may when all the firmware bug stuff was happening. Mine was ok after the 1st firmware bug fix. But i know others have had issues and they have put out several more firmware updates since may trying to fix it. My batteries have been fine since may
Message 4 of 5
8,116
There was a bug causing the ir lights to stay on in the camera. For me its fixed. Others still having issues. Some still having fast battery drain and cameras going offline on and off. In may mine would drop 10% overnight even with camera turned off. Now it stays where it should and does not drop overnight
Message 5 of 5
8,113
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
