  • 1 Reply
  • 728 Views
RinMichigan
Currently, you cannot add geofencing as a scheduled event in the "schedule" mode. For instance, it would be great to have geofencing turned on during the day when I'm coming and going from my house, but also have the system armed when I'm home during the night. Right now this has to be set manually. I would like this switch in modes to occur automatically by me performing the proper set-up in the schedule routine. It seems this would be a logical thing to allow. Is this change something that can be done and done soon?
RinMichigan,
Geofencing activates desired modes based on location when enabled. Currently, there are options for Home and Away triggers for this feature.
It sounds like you are wanting your Home trigger (within Geofencing settings) set to schedule and then your schedule set up with an active motion detecting mode during desired hours. This will result in motion detection enabling during the desired hours and no motion detection during unscheduled hours.
