4th camera install
I purchased a 4 cam unit in January and was only able to install 3 of the 4 cams due to weather. My 3rd camera never shows any last recorded images on both the app and desktop so I have to have manually click "live" button to view an image/vid. I recently installed the 4th camera and it works flawlessly.
Will arlo replace my 3rd camera under warranty?
Message 1 of 3
1,688
Usually to fix the problem if the camera is streaming ok , Is to delete/remove the camera completely and just bring it back again as a new one.
Also open the battery door and reset the camera before adding back in.
Message 2 of 3
1,684
I've re synced it taken out the batteries etc etc. No luck. However net gear support offered another potential approach. Plugging it into a USB port over night via the mini port when the batteries are removed. I'll have to wait for better weather first as it is outside and high
Message 3 of 3
1,633
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
