Motion being detected with no motion on multiple cameras in multiple areas
  • 1 Reply
  • 1198 Views
shopkins1994
Hi everyone. All of the sudden about 5 various cameras all over my house and outside are detecting motion when there is no motion. I've set them to 60-70% and still they endlessly detect motion. Did something change?
It could be movement of branches or leaves, angle of the sun causing IR reflections, fast-moving objects (birds, etc.) but the first thing I'd try is power-cycling the base.  If it continues, you may need to remove all devices from your account, factory reset the base and resync all cameras.  PITA but it may be needed.
