  • 2 Replies
  • 1318 Views
MarioCruz
Hi, I have my cameras for a week on my restaurante and the batteries are already off!! It was supposed to last 6 months!! Is it possible to program the cameras to work only when I check the camras on the mobile app in order to save battery life? or do I need to disarm and arm every time I want to check? thanks
I have to wireless cameras on a restaurante with 190sqm
Schorschi
Prodigy
Prodigy
How many videos clips have you recorded? What is the total length of video recording? A lot of videos per day will use up the battery fast.
What is the distance between camera and base station? A long distance will use more battery power, because the camera has to work harder to connect to the base station.
Nominal use-case for the Arlo wireless cameras is a four-minute video clip per day. It will last 4-6 months then. If you have more than that, your camera won't last that long.
You certainly can do this. In the Mode tab, select your system and then click on Disarmed. Now you won't record anything - you'll need to use Live View to check on things as well as to record anything.
As noted previous, the batteries will run down quickly if recording a lot. The same is true of using live view too much. You can work with your modes, rules and schedule to allow it to work for you but remember the 4 minutes per day to get the best battery life.
